Looker Studio with Coda
Hello guys.
Have any of you ever connected Coda with Looker Studio? I’m looking on how to do it, but i can’t find if there’s any way Looker allows this.
I have. But not directly.
The easiest way to do it is to set up an automatic export from Looker > Google Sheets
Then, either using a script or a pack Sync the google sheet to a Coda doc.
Let me know if you have any other questions!
@Scott_Collier-Weir
I’m trying to make a community conector so we can connect Coda to Looker, but i’m looking to make it the other way around. Send information from Coda to Looker
Yes! A community connector for Coda would be awesome. You can use the Coda API to build one. Let me know if any issues arise along the way.
Hi Eric. I think if the coda team would take a look and refine this integration Coda | Airbyte Documentation it would enable a whole slew of integrations including Looker.
hello good @eric_koleda , I would like to create this same thing but I can’t find any information, could you guide me more or less how I should do it?
Hi @sergio_cerrato_gonzalezz - I’m not an expert in Looker Studio, you’ll have to confront their documentation on what you need to build. But I believe that the Coda API should give you enough access to the columns and rows to allow you to build one.
I find a serious problem, because I have to look for the code of the table and the fields to save them in variables are short I can only save 200 fields in a variable, then it is unfeasible to implement this, so I want to see or implement something so you can read the table and with the reading of the table to send it, I do not think that I have problems when implementing the api of looker but at the time of collecting the data, so I would like to be able to make a table selector and having that selector a button that executes the import to loker studio but the lack of knowledge of the api of coda and the limitations that it has as I have commented the 200 fields in a variable limit me in my implementation.
Can you clarify what you mean by this? Where is this limitation, in the Coda API or in the Looker Studio?
Yes, of course, the problem is when I use the coda API, I try to get the rows and store them in a data variable , when I try to do it with tables bigger than 200 rows for example 11000 or 250 it only keeps 200 rows of all of them so it makes it incomplete and I can’t have the table data as a variable
When you list items using the API you often need to use pagination, retrieving the results in batches. You can learn more about it here:
https://coda.io/developers/apis/v1#list-endpoints
