Dear all,
apologies for the basic question. I can’t seem to work out the following. Any help would be great appreciated.
In my illustration above I have marked in Red what I would like to achieve. I’m not sure how to go about writing the formula to achieve this.
I’ve described in words below what I’m trying to make.
e.g.
I would like to populate the “Server Cost” row with cost data from the “Cost” column and row IF the “Item” Column & row contains “Server”
Let me know if this is unclear or if anyone has advice.
regards,
Sean.
Ben_Lee
2
A simple “IF” statement in each column should work fine. Just add the following as formulas for the columns.
Storage Cost
If(Item="Storage",Cost,"")
Server Cost
If(Item="Server",Cost,"")
Service Cost
If(Item="Service",Cost,"")
If this is to sum or use this data in different ways, Coda can filter and calculate quite a bit without needing to add extra columns.
As an example, enter this equation into the canvas (anywhere in the document empty space, just type “=”) and it will sum all your Server costs.
[Table 2].Filter(Item="Server").Cost.Sum()
Thanks very much for this. Solve my problem.
Sorry for my slow response.
Cheers,
Sean.
Ben_Lee
4
No worries. I’m glad it worked for you!
