Make a Bill Tracker
Hello,
I’ve heard alot about Coda and I’m excited to see what I can do with Coda.
One thing I really want to make is a bill tracker. What I want a bill tracker in which the total amount due is adjusted as I pay my bills throughout the month. For example, I have a table with five bills with a total of $597. I pay a bill that is $100. I want the total bill due amount to reflect that I now have $497 due.
Is there a way to mark a row completed and have that specific bill amount subtracted from the total bill amount?
Yup! Add a checkbox column called ‘Paid’, and then you can use a filter, so you can do the following (assuming your table is called ‘Bills’, and you have a column ‘Amount’ which is what you’re adding up:
Bills.Filter(Paid = false()).Amount.Sum()
that did not work nothing happened. I get an error message saying “We don’t know how to handle this part of the formula.”
Check out the Filtered Total example here:
If you are still having difficulty, could you please share a doc so I can check it out?
Joe
https://coda.io/d/Untitled_djoMsR89ep0/_suZG1
No access, please grant.
Have a look now, should be good.
