Make embedded github gist wider
If I embed a github gist URL into a doc, it shows up but is quite narrow:
Is there anyway to widen the gist display?
Link to the doc: https://coda.io/@eduardo-cavazos/jre-video-list
Also included below.
If you highlight the embedded gist, the highlighted border should have squares to drag and resize. If it’s not wanting to highlight this way, put your cursor to the right of the embed and arrow left to highlight it.
If it doesn’t resize like an image, post back and we’ll take another look.
Ah… So yeah, I had been highlighting it, however the gist is so tall and the resize squares are centered vertically, so they were offscreen:
If I scroll down a ways, I see the resizers:
Maybe placing additional resize squares on the element is something for the UI team to consider.
I’m good now, thanks! :slight_smile:
