Hi,
I’m trying to make this wider :
This is a composed content from two columns.
Display’s not wide enough when displaying text, or canvas column, but it’s ok when displaying a select field.
Is there any way to change a group width on the fly ?
Thanks
Hey @Garry_Techer ! Thanks for reaching out. While this is not possible at this time, this sounds like a feature request the Coda team has been tracking to wrap content from Compose columns. I’ve moved this post into the Suggestion Box for other members of the Community to chime in on this. In the meantime, we recommend simply using the drag handle to adjust column size as shown here: Screen Recording on 2024-07-17 at 02-51-10.gif - Droplr
I did not see this was possible.
This is exactly what I needed thanks.
