Hi Friends,
I’m trying to create a lead table in which every rep see’s only his leads, so I filter by “current user”.
But I also want the head of sales, who also enters the leads to this table, to see everyones leads, what’s the best way to do that?
Thanks,
T.
Write another filter that says “or user()=@salesLead”
So the logic is saying:
Show rows in this table only where the current user is assigned to a lead UNLESS you are the sales lead”
You will have to use a formula for that filter rather than the normal UI editor
Thanks, it’ll be my first use of Formals, so wish me luck
Thanks @Scott_Collier-Weir
Ok, it didn’t work, this is what I did
and this is what I got
and of course it’s not working… what did I miss?
Thanks,
T.
Thanks @Scott_Collier-Weir , I think it worked!!
and I learned a lot on the way.
So glad! Learning step by step is the only way to get there
Figured this out, but can’t find how to delete post
