Modify Rows by Matching Lookup Values / Inventory Management / Action Modify Row .Filter
My scenario is as follows:
I have Table A with two rows whose values are:
  • Banana
  • Orange
It uses a second column to tell me the number of each fruit I need
I have Table B which has two columns
  • Quantity (a number)
  • Fruit (a lookup field listing Table A fruit option)
I wish to add TableB.Quantity to TableA.FruitNumber of the appropriate fruit chosen from the lookup field TableB.Fruit. I would think that a button with the function of Modify Rows>Filter>+TableB.Quantity would work, but it does not. Can anyone share some formula that I can use to tackle this.
Here’s the formula that i’ve tried - it gives me no errors, but will only alert me “No action taken” when I press the button.
ModifyRows(Filter(TableB, thisRow.[Fruit]=[Fruit Type]), TableB,[Number of Fruit], +thisRow.[Quantity])
Hello,
Did you ever manage to find your solution?
Thank you
Nope. here’s the other 20 characters needed to post this
Hey @P_C –
To add the values from B to A — look at the ADDING THE TWO button. Try this:
ModifyRows(thisRow, thisRow.[Fruit Number], [Table B].Lookup([Table B].Fruit, thisRow).Quantity + thisRow.[Fruit Number])
To replace the values: her are a few options.
Option A:
I dont think this is the most efficient formula, however, this formula works for a button:
FormulaMap([Table A], WithName(CurrentValue, [Fruit A], ModifyRows(CurrentValue,[Fruit Number], [Table B].Filter(Fruit.[Fruit Type] = [fruit a].[Fruit Type]).Quantity)))
Option B
You could also create another column in your Table A that is a reverse lookup to the quantities set in Table B. From here you can have the button update the Values from the reverse lookup setup.
Option C
Or add a button to each row.
