Move hidden columns in layout
Hi Guys,
i don’t know if this is known or even wanted but i recognized it is not possible to move or custom order the hidden columns in the layout view…
https://youtu.be/8rmTQn-0e00
Would really appreciate if that would get fixed asap.
Thanks to the coda team.
Sincerely
Jannis
They are usually hidden for a good reason. Having them in Alphabetical order in de hidden section makes them easy to find. If you find you are using some hidden fields frequently, I suggest you make an extra layout, attach it to a (hidden) view of your table and open the specific row with a button and call that layout (view):
Okay, thanks for that explanation @joost_mineur.
So there is currently no other solution to use a custom order than using a button and select a different layout?
Sincerely
Jannis
No, for the hidden fields there isn’t - as far as I know.
Okay, thanks @joost_mineur.
Sincerely
Jannis
