Multiple buttons on the same line on cards view
Is there a way to show something like below in a card view?
ordered-canceled
Hey Chris! It’s possible but it’s not very dev-friendly.
The key is to use Concatenate with the hidden Button formula, I updated an existing experiment with a card view for you at the bottom
Great example! How would you use the color formula in the 46Table cards view?
Thanks Rickard,
That worked but I had to have all the column buttons and texts on the same table, since some of the actions of the buttons depend on contents of the table
