Hello there,
I have a 3rd party data collection tool which is linked to my Coda doc, but the data that comes through the data collection tool includes several records per row. Is there a way to get these as 1 record per row in a separate table?
Thank you,
Tzviatko
Thanks for the lightning fast response @Scott_Collier-Weir !
Making the adjustments before the data comes into the Coda doc is a much more elegant solution
thank you!
Here is my AddRow formula and this now works fine, just a couple of questions to optimize it:
Is there a way to ignore blank entries from the form. For example if ID_03 and Status_03 are empty, with the current formula a blank row will be added to the Coda table, which is not ideal.
If I have a large number of entries in the form (they go up to ID_20 and Status_20), is there a more efficient formula I can use instead of repeating the AddRow formula 20 times.
Tzviatko
Yes! There is a more efficient way. It will be by creating an index for a forEach() loop through use of Sequence(1, totalItemCount) and looping through that
A bit more complex of a solve, but if the keys In your JSON are consistent like that it could work. Better shown than typed.
Can you share a doc with an example JSON payload?
Thanks Scott, I’m happy to hear there is a better way!
Here is an embed that describes the source data and shows the table that I would like populated with this data:
I’ve looked up forEach() loops a bit but I still can’t figure it out.
Tzviatko
Thanks! Does that doc have an actual json payload in it?
EDIT: Actually, I got it! Busy for the next couple hours but should be able to get to it tonight hopefully!
Alright here you go - This is what I would do:
And here’s the doc link that you can see the button in it working.
Couple things to note:
- Yours will be different, because you will be doing it in an automation, and therefore where Im accessing
JSON you are going to be accessing Step1Result
- In order to find the number of keys in your JSON object, Im splitting on a
: character. This will only work in situations where your incoming object is NOT nested and doesn’t contain a : anywhere but to separate keys and values.
- You can’t simply divide by 2 in the sequence formula IF the actual object has other keys that are unrelated to your status/id keys that you are after.
Again - coda is not great at working with Objects, it’s great at working with lists. If you need more complex object manipulation, best to pass the data first through a script outside of Coda and then use the API to add the rows.
Personally, I’d do it through a google apps script (Catch your webhooks in the apps script, parse the payload there, and then use Coda’s API to add the rows.
@Scott_Collier-Weir you are a legend! Thank you so much - this works perfectly!
And I appreciate the detailed, step by step explanation. Thanks!
It looks like I may have to change the field naming convention in the source so it doesn’t have the trailing 0 in front of single digits (ID_1 instead of ID_01), and slightly modify the formula you shared to better accommodate for the double digit index values so the loop looks for ID_11 instead of ID_011, etc.
ParseJSON(
Format("ID_{1}", CurrentValue) //change this from "ID_0{1}"
Thank you!
