Need help with formula - substraction of time
Hello everyone!
I need help with a simple formula (not simple for me hehe). I am trying to figure out how much time it takes for our agents to call a lead (Time To Action column). I had a decent idea of that by using lastmodified-generated on, but this doesn’t take into account the duration of the first call, so it’s wrong by a couple minutes since the stage is only modified after the call. I would need a formula looking like this :
Lastmodified - generated on – time of first call
This would allow us to know exactly how much time it took for the agent to call the lead.
Any help is truly appreciated, thanks🙏
Your formula should work :slight_smile: You can subtract tow DateTime’s and get Duration as a result, then subtract another Duration.
Thank you @Denis_Peshekhonov , it worked! :laughing:
You seem very good at this, think you could help me with this sheet? I wrote what i’m looking for on the sheet:
*Any help is truly appreciated
