NetWorkingDays formula bug: result is offset by 1 in either direction
This appears to be new, at least I noticed it today:
I generally use my own formulas, but I think networkingdays has always been working like it does now.
The formula guide shows a sample with a calculation just like your sample, but the explanation (“between”) contradicts that. I guess once you know, it is easy to use the formula in a way that works for your purpose. Personally, I like the way it works and I would prefer for the formula guide to adjust the explaining text.
It’s inclusive in either direction :man_shrugging: So giving it the same day is 1 day (that day), giving it the previous day is -2 days (this one and the past one, moving backwards hence the minus)
Alright thanks all, somehow I missed this as the previous behavior. Odd behavior but obviously it would break documents to change it, so thanks for pointing this out and I can just adjust my document.
