New section and filename icons
Regarding these new section and filename icons:
  1. Is there some way to select from an entire list of available icons?
  2. Or are available options only accessible via search strings?
  3. If (2), is there a complete list some place that we can reference when typing in search strings?
section_icons_2019-01-25_0755
Hi @Ander - currently we do not expose all the icons (over 4000) in one place and they are only available via search string.
@mallika - is there any way to add custom icons for sections and folders beyond the existing set of 4000?
Does anyone know which library of icons Coda is using?
I think its this one: https://icons8.com/icons/
I also vote for a section where we can see all icons used. It’s so difficult to find the right one and in a similar style now.
Hi mallika! Wondering if this has been updated and if we could see the entire list of ~4000+ icons somewhere?
Hi @Fawziyah_Nabeelah ! We source our icons from a 3rd party, a subset of the icons8 library, and while we try to refresh at regular intervals, we may not be able to offer a 1:1 match for everything in their library. Unfortunately we cannot guarantee when those updates will occur.
We don’t currently have the functionality to add custom icons, we are tracking this as a feature request! That said, I’ve gone ahead and moved this topic into the Suggestion Box for others to get involved in this request to add custom icons.
Thank you for replying @Shania_Torgerson!
until then-- is there a way to have a possibly-easy-to-add-specific-icons suggestion box/table with reactions for votes?? about the possible specific icons to be added to the existing collection? Like not another post, I feel icon-request posts may be repetitive and the collective votes are not aggregating for the same suggestion.
For eg. I would like icons for companies like google, apple and other well-known ones as there are already some icons for fb, netflix, linkedin etc my doc feels incomplete without the missing ones which I think can be quick adds? idk… :frowning:
I also don’t know if those specific icon suggestions I’m looking for are going to be in the next-refresh interval- is it possible to have something like this public?
