On forms, is there a way to have fields appear based on a picklist selection?
I have form that I’m thinking about that will show/hide a field based on a previous yes/no picklist. Is this possible in Coda?
Hi @mattics,
short answer: this is not possible at the moment.
If you want, you can add this as a feature request in Suggestion Box.
Best regards
Jannis
got it, thank you jannis! i will go and suggest it as a new feature request :slight_smile:
Okay :+1:
Best regards
Jannis
