We use Plectica for our thinking & mind mapping. Would be great to be able to connect this with our Jira Issues & Figma Files so our devs have context.
I dosen’t know Pletica before.
Realy nice tool for diagrams, I gona start using it to
I do not have sure how to conect they to coda, because they not look to have a API or some sort of importation of data.
But for now, you can embed your boards to inside coda, that maybe help your workflow
If you whant to make the data in coda go to a card in a flowchat, or something like that, you can use Lucidchart.
Lucidchart import data from Google Sheets, so you can connect coda to Sheets and see your data in Lucidchart.
