Performance Issues - More than 25+ seconds to open docs
Hi Codas,
We’ve covered issues about performances in several different threads.
I can’t stress enough the huge problems we have in loading certain docs (startup time) when on Mobile both in Android and iOS and with different network conditions fast 4G / strong Wifi.
I’m struggling with 25/30 seconds startup loading times that make a quick insert into a table or Canvas almost impossible. This makes the use of Coda Mobile almost useless since people can give up at a certain point…
Is there something coming up in your roadmap that will address those issues?
Here’s a gif with an iPad 2018:
697C4362-C304-4E03-A92A-27EA6EAE5874
Dear @Francesco_Pistillo,
As the community will not be able to support you, maybe contacting support@coda.io is a better approach.
Of course when there comes up relevant news on the developments, the community becomes the right place for updates
I know it’s been a while, but hopefully you’ve seen our latest updates to doc performance! Update: Our continued commitment to performance
