I already asked this a long time ago here Card view tweaks, and I really think this is an important fix to work with card view.
Actually as you can see on the picture, the text is cropped from the showing fields. In this case, those are tasks, and I feel that it is very annoying to open the card to see all the text.
Please, do something about this (and about my requests on card view
I’d like the same - a bit discouraged that this is from 2018
Is this the only time this has been requested or suggested? this is crazy if so. the ability to show all text without truncation (within some reasonable greater length) is so essential.
Although I agree there should be a setting to define the card length, there is a work around that might help you out:
