Please Help! Realtion column filtered by two matching columns
I got off on the wrong foot on another post trying to get some help with a formula that has been incredibly frustrating. So first off apologies for my attitude.
I have used gemini, superhero all recommended the same formula and nothing works. It seems like something that should be incredibly easy, Have one relation column filter by the project its related to and the tag associated with it
in fact this is all I need, I don’t want one or the other but both. project = project and scope tag= scope tag.
Anybody able to help with this?
I requested access to your document.
Thanks just approved your request
hi, use formula for multi condition
Can you elaborate? I’m not very good with formulas, and every formula I used recommended by Gemini and superhuman doesn’t work.
thisrow.project == currentValue.project && thisrow.Scope.. == currentValue.Scope...
That didnt work. It doesnt recognize the way you added current row, or the && symbols
What are you trying to do? Autofill or filtered selection? They’re not the same thing. Right now you’re in default value.
If you have a limited selection, go to filter and custom filter and use this formula.
Please check your doc.
