I have a sync table with many rows (1000 or more), from which I am calculating various statistics and plotting the data on a chart:
My pack generates the data using the parameters in the callout box on the left, combined with some randomness - so a user would likely change the settings and click “Generate” many times during a session.
But when the table is syncing, I do not get a clean transition to the next dataset. My charts and my formula calculations flicker and recalculate as the new data arrives. Due to the size of the dataset, this can take a while.
I would like to create a true/false property in my doc that knows the current sync status. If syncing=true, I can then tell all of my formulas to show up as blank until it’s complete, and the user experience would feel much more solid.
Is this possible?
