Print as PDF "function" does not work any longer [fixed]
Hi Community,
in the past I was able (and happy) with the print as PDF option. My report looks like this:
and the created PDF looked like this:
So format colours etc. have been displayed in the PDF. Since the 2.0 launch I got this result:
All formats have disappeared and it looks like the content is being moved.
I have this behavior with all documents and currently can’t find a work around that creates a PDF, which represents the content including the colors.
Is this also the case with you? Did I miss something?
Thank you for your advice.
Thomas
The problem is fixed today!
Thanks coda!!
For future reference, the nicest way to generate a static version of your table(s) that I’ve found, is to use the Gmail Pack to email a Section to yourself. The output looks relatively great (it doesn’t chop off the edge of the page–although I haven’t tried to print the email yet). I feel like if Coda used the same routine for the Print function, it would work well!
Hi,
thx for the nice work around.
Cheers Thomas
