Print multiple invoices at once
Hi all,
I’m trying to extract the notes from a canvas column that includes a subtable.
Looks like the followoing:
I’ve used a simple formula that requests the row’s column info: [Meeting Notes Selector].Notes
And what I get extracted is the text, but not the table:
I do get a hyperlink to ‘Tasks 2’. But that hyperlink only takes me back to the parent note table, not even into the correct canvas.
Anyone know why? Or know a solution?
Thanks,
Matt
Hey @Matthew_Shane! I recommend setting up subtables instead, then you could use format or concatenate with some formulas to pull the text and then add a bulleted list of the table rows. I’ve also added a vote for you to a feature request for better handling of printing canvas column content :smiley:
