Programmatically invoke refresh of synced tables/columns
Hi there,
I searched extensively the community to find a solution to programmatically invoke refresh of synced tables/columns and I realized that it can’t be done through automations.
Is there any other way to do that?
I really need to do that and I can’t figure out if that even possible.
Thanks.
I don’t think that’s possible from what I recall, but @Eric_Koleda can probably help.
That’s correct, the only way to refresh sync tables are:
  1. Push a button
  2. Set an automatic refresh interval (1 day or 1 hour, availability depends on plan)
It would be a really nice if the automatic daily sync time could be adjusted somewhere. I often want the sync to happen when others aren’t in the doc, or prior to some other automations running, but my understanding is the time is just when it’s enabled, which is generally going to be working hours.
