Pushing to g-cal
Hey all,
It is very possible I have just missed something extremely simple, but having done some searching in help docs and the forum, I can’t for the life of me figure out if I can push a coda calendar to a gcal rather than the other way around?
I’m fairly certain 2 way sync isn’t possible? (This would be very helpful).
I think I can get folk here using just the coda doc to update / use the g-cal to communicate with others who are not using our coda / use g-cal for the rest of their day planning etc.
Could anyone point to the docs on this?
Many thanks.
Hi @Brendan_Woithe,
it is indeed possible doing it! :slightly_smiling_face:
Have a look at the functions reference for Google Calendar: Reference.
Also, if you want to have a good working and inspirational example, take a look at Des’s Prioritised Productivity Guide, which has 2 ways integration with Google Calendar and (one-way, in this case) with GMail.
Let me know if this helps.
Oh thanks for this! I’m back working on our business coda document next week so will give this a red hot go!
Here’s a simple template with the buttons and suggested settings for creating events and updating them…
