Hi there,
I am trying to do a basic naming convention, taking the name of a few columns to create a name for each line.
Here is the formula,
thisRow.[#] +“_”+ thisRow.[Owner OS _ Program Milestones]
I have attached a copy of the output. Any ideas on how to fix this_
Thanks,
Andy
@Andy_Farquharson2
welcome to the community !
have you tried to use Concatenate() or Format() formulas
hope this helps!
cheers!
Mel
Hi Andy,
Welcome to the Community!
Do you want the answer to be “0 Welcome” ? “+” is a mathematical operator, to join the contents of columns to together, you need to use Concatenate(), Something like Concatenate(#, “ “, Owner OS_Program Milestone)
Also bear in mind that it is generally not a good idea to use special characters at the beginning of a column name.
Regards
Piet
THanks for the quick replies. This solves my problem, thank you!
