Rename files uploaded within tables
I’d love the ability to be able to rename files that I’ve uploaded to a table.
Im going to revive this because this comes up in my workflow all the time. It is more efficient to upload the file then be able to rename it once it is in the table.
Yes, it would indeed be super useful !
Still not possible in 2023?
I would love to have this option as well :slight_smile:
One of the MAIN goals for the file organizer application I’m prototyping using Coda.
In my case I’d like to copy a pathname from Windows Explorer and Paste it into a table cell (using a cough, a Paste Button), along with some additional Select columns for choosing tags and other informational metadata about the file, all of which then gets concatenated into the new pathname column where I can then click a Copy button to then rename the file back in the file explorer.
Being able to encrypt or garble / make unique (GUID) a text table cell (filename) to avoid name collisions etc., would be icing on the cake…
Anyone found a workaround?
Yup, I am dealing with this issue right now…
They there! Alison here from support. A great way for us to track feature requests is to submit them through support. Feel free to shoot us an email at support@coda.io or hit the question mark in the corner of your doc and after a few questions we’ll get that logged for you!
