Return Number Ranges
Hello, I have another problem which I would like some assistance. I solved this one in filemaker, and need to adapt from the solution.
I would like to allow the user to input a list of numerical IDs using ranges or lists. For example:
User Input text field: 101-105, 7-9
Would appear in an array as:
101
102
103
104
105
7
8
9
In filemaker, I parse the numbers, hyphens and commas, and loop through, generating the array.
This way I can lookup information about each of these items.
Thanks in advance, and I’m loving my time here with Coda
Hi @Nick_Solyom,
Basically, you do the same in Coda:
Formula is:
thisRow.Ranges.Split(",")
  .FormulaMap(CurrentValue.Split("-"))
    .FormulaMap(CurrentValue.WithName(range,
      Sequence(range.First().ToNumber(), range.Last().ToNumber())
  .ListCombine()
  .Sort()
I hope this helps.
Cheers!
