Return Specific Column Values in Automation Notification
I’m trying to wrap my head around how to send a notification when a particular row is modified, with a crafted message (using fields from the table) in the automation notification.
Here’s the message I want delivered…
"{Name} has {status} the invitation to speak about {topic} on {date assigned}.
When I try the automations, I keep getting lists returned, not individual values like I would want.
Here’s a working concept doc for it… where I am failing…
How can I automate the notification to be on par with what I am thinking?
Want it to read, at the time of status change… something like, "
“Bill Baker has accepted the invitation to speak about “Cookies and Cream” on 11/6/2022.”
Totally lost, running in circles, trying to get this one sorted out in my brain.
Hi @brownrbrian
I corrected directly in your documentation, here are the configuration you should have written. Actually, you have to use “Step 1 result” to get information from the changed row
  • Little mistake in the if statment, here you go with something simpler that expected !
  • Then the written message for notification ( you can also use Format() function for this which is more elegant)
And VOILA !
@Quentin_Morel stellar! So simple. :man_facepalming:!
Updated it to use Format, much cleaner. Appreciate the support!
At the beginning this is just to understand how to use Step 1 Result :wink:
Happy to be helpful.
Cheers
