Right-side label style
In forms and layouts, formatting offers two label styles: “Standard” (above the field) or “Left” (of the field). It’d be great to have a third label style: “Right”.
The use case is for “I agree/consent” texts on forms: Having the checkbox on the left of the text, i.e. the label on the right of the control, is what users expect on the web. This is currently not possible in the layout editor.
Ran into this same use case recently too. Sounds niche at first, but I wouldn’t be surprised to see it in like 50% of forms.
Hello @Sebastien ,
Using a selectlist type column or a filtered relation type column does the trick too (wit a lot of extra options, for that matter). I use it all over the place.
Depending on what you want to do with the checked items it can require a bit of programming, but it is not very complicated.
Greetings, Joost
