Hi
i could have sworn i had this working but guess not.
i am using a coda form for people to log faults with equipment we have. the form needs to generate a fault id number (this works) and the number needs to be visible on the published form so that the person reporting can write the number on the equipment.
i have cur following forma for generating the fault id
Format(
“FAULT_ID {1:0000}”,
thisRow.RowId()
but on the form this always returns FAULT_ID 0000 on the form. but once you submit the form it shows up on the table with the row id number as it should.
yes i have include reference tables enabled and i get the same behaviour within coda.
any help would be greatly appreciated.
