Salesforce Dashboard in Coda
Hi! Does anyone know if you can embed a salesforce dashboard into Coda?
Thanks,
Hannah
hi Hannah,
Depends a little what you mean with “Embed”. If you have an URL, and permission to access the underlying resource, you can embed many things.
If want to communicate between Salesforce and Coda, it would depend on whether there is a integration interface like Zapier available - I cannot recall seeing a Salesforce pack.
Alternatively, you can go hardcore, and use the Coda API yourself… :wink:
Regards
Piet
Hi there Hannah,
We have a Packs Request form here: Request a pack - You can upvote for a Salesforce Pack.
