Same table lookup?
Hi everyone!
Is there a way to create a kind of lookup (formatted in a select list) inside the same table from which I want to pull the data?
Thanks for your help!
  • Author replied! edited post -
Lookup (as a column type) is done per row (given a table + column to lookup values in), not over columns per row.
I.e.: Lookup asks for a specific row, not a specific column.
If you setup your table with each agent being a row, then you can perform a Lookup on it.
You probably then want your dropdown formula to go on the outside.
The alternative is that you can do a lookup over columns by providing the values for the dropdown via a formula, but you will need to add the columns manually everytime you add or remove them:
(In your example: List(thisRow.[Agent 1], thisRow.[Agent 2], thisRow.[Agent 3]) as the Selectable Options for the first Column.)
Exactly what I was looking for, thank you!
