Hello! i noticed Coda’s performance issues when running semi-large data sets up to 1000 rows of data
is it possible if we store the rows of data at external Databases such as backendless or xeno? while using coda as a frontend?
Yes possible, but you must build your own Coda pack
I would just like to add for accuracy sake, problems starts around 10,000 lines, an order of magnitude larger than in the OP.
In case anyone else is looking at this - our team just launched the Xano pack for Coda! Row-limits are now a thing of the past as you can grow easily into the millions of rows in Xano and use Coda as your front-end
