Scanning for Malware very slow, doesnt work
Somehow the Upload and Scanning for Malware takes very long…actually doesnt work anymore.
I copied my task list into another sheet and shared it here, so you can try.
In this community Doc i have no extra packs and links what so ever. It is extremly frustrating, becaus i build this very good tool and i took me quite a while and now i have this issue. It seems its always the images which make an issue.
Can you help me out please?
Yep something seems wrong with the file scanning, I’m getting stuck too.
They reported it an hour ago here https://status.coda.io/
I’m having the same issue.
Having the same issue, all file uploads stuck on the scanning part. Hopefully this is a temporary glitch and the files are not lost as we are facing this issue with data submitted by users trough forms.
It’s unfortunate that no one at coda support is reachable to fix this.
EDIT: Ah, now I see from the link Rickard posted that the coda team is aware of this. This should really be a banner so we are aware that there is an issue and that it is being worked on instead of a subdomain most users probably didn’t know existed.
I am having the same problem.
Yeah it’s not very visible as you’re saying, I’m also subscribed to those posts but I wasn’t notified :thinking:
It is one thing that the systems detect an issue, it is something else to have an engineer looking at (must be awake) it and this all is totally different from communicating about it.
They came back to me. Coda is having an issue with there file processor. Scanii. So lets hope they can fix it soon.
