Is it possible to find all formulas that reference a particular column?
Easiest way is to delete the column, get the pop-up listing all references, and then cancel the deletion ![]()
Hi Blaz,
@Scott_Collier-Weir’s Doc Explorer might give you your answer - it can list, for all tables, the formulas in that table. You can then search the fomula column:
Hope that helps.
P
