Select Default Workspace
Continuing the discussion from Launched: A cleaner home for docs and workspaces:
@Steve_Won I would like to request the ability to Select Default Workspace
  1. currently in the coda dashboard (https://coda.io/docs) workspaces are sorted alphabetically. For example, my primary workspace beings with the letter “P” which is located underneath a workspace that I am invited to (but I don’t use) that begins with the letter “C”. My primary workspace should be at the top, regardless of naming convention, please. :point_down:
  1. When I copy a doc, I would like to not have to scroll down and select the destination workspace. Ideally the default workspace should appear at the top of the pop-up AND should already be selected, please. :point_down:
2021-09-30 at 09.29AM
Thanks for sharing @jeo . We will take this feedback into account as we continue improving the doc list and workspaces experience!
I’m having the same problem. It is very irritating that I have to select my workspace each time. Also when I look for packs, my workspace’s docs are not in the list, only the workspace’s docs at the top of the list are listed.
