Select List: Hide or Remove "Blank"
Is it possible to hide remove the “Blank” option from my Select Lists? Or at least have it appear at the bottom?
Nope, not possible when you use a select list in a table. Only if the select list is on canvas or if you are using a relation in a column/canvas.
There is no easy way to remove “Blank” from the drop down, but you can have an automation that maps any “Blank” to some other default setting.
