Hey there!
I’ve got an issue when i try to combine a canvas from another page to a string in the content field of button with gmail send email function. Is there a trick ?
Thanks for the tool btw!
Alexis
Hey there!
Alexis
Hey @Alexis_ANZIEU
have you tried combining them with the formula „concatinate()“?
Hi Alexis
Unfortunately we do not support adding text to a section as yet. When using a section to send an email all of the content should be in the section. You can not change the content afterwords. We are working on improving this but in the meanwhile you can try one of the following alternatives.
Here is a document that has both the examples - https://coda.io/d/Concatenate-ranges-example_dAnBLc-iBd1/Templated-ranges_suAnC#_ludZm
We realize that none of these alternatives would be as powerful if you were able to operate on canvas. We are hopeful we would be able to allow you to operate on canvas soon.
Thanks
Himanshu
Hello!
Okay, thanks a lot for your answer
Cheers,
Alexis
