Sequencial Copy of Numbers in Coda Doc
Can we copy the numbers in sequence in the Coda Doc?
Ex:
1
2
3
Can you be a bit more specific in what you want to do with these numbers?
One option is to look into the Sequence(start, end, stepsize) formula.
So for a list of numbers from 1 to 3, this would be =Sequence(1,3) (stepsize is 1 by default).
hi @Secret_Admirer, is this what you are looking for?
Thanks for the ideas.
So what I mean is, if you recall how copying a number onto multiple columns works in Excel (+ Symbol and dragdown)?
Similarly in excel, when we drag the number onto multiple columns, then right click and select ‘Fill series’, the number gets into a series and fill out the rest of the selected columns in a sequence?
So do we have an option as ‘Fill series’ in Coda? Just as in Excel?
Dear @Secret_Admirer,
There is no simular "fill series as in Excel, available in Coda.
Depending on the usecase you can use the method as explained by @GJ_Roelofs or what comes in my mind adding rows with the required sequence by using a button.
Success, :handshake:
Some other suggestions here:
