Set value of a Date Range control
Hi guys, I have a Date Range control and I’d like to set its value to a certain range, e.g. This Month or Past 180 days. There is the Set Control Value function but I can’t find an appropriate object to use as the value. Is there a way how to do it?
Thank you
Jan
Dear @Jan_Hink,
It’s always recommended to provide a dummy doc or screenshot.
Does the below explain what you are looking for?
Hi @Jean_Pierre_Traets,
sorry for not being clear. I’m talking about setting the range control’s value using a Set Control Value formula. In other words, I already have such interactive date range input and I’d like to set its value to e.g. “Last 180 days” by clicking a button. I thought I could use the Set Control Value formula in the button but I can’t find a way to do it.
Is that even possible now?
Best regards,
Jan
Hi @Jan_Hink ,
unfortunately this is not possible.
However, you can easily workaround with it by just putting a flag control and - if true - you set the filter to last 180 days.
Otherwise you take the control value parameters.
Have a look at this simple example:
Let me know if it’s not clear.
Cheers!
I may be misunderstanding, but I think this is possible:
You have to first put it into a list by the looks of things.
Amazing @Connor_McCormick :trophy: :trophy: :trophy:
This is exactly it! Thank you very much @Connor_McCormick, you’re a life saver!
Cheers,
Jan
This is great @Connor_McCormick! :+1:t2:
I haven’t dug into setControlValue enough, yet: thank you.
@Jan_Hink apologies for wrongly pointed out it was not possible.
Dear @Federico_Stefanato and @Jan_Hink ,
The support provided on this platform is free of charge and even more important at our best knowledge.:hatching_chick:
In many cases, the solution provided is not the only option, but a proposal.:clapper:
The most important from this thread is that @Connor_McCormick made us aware of something that till recently was not possible in Coda.:thinking:
