Share tables over 2 documents
Hi all, is it possible sharing data/tables within more than one document, e.g. we have several information (like contacts) we would like to maintain only once
An “Include” Library feature, or alternatively syncing data to an external file, would be wonderful features. However they are not available at present.
The closest workaround would be to use Zapier integration to update one or both Coda tables whenever changes are made. But that is not nearly as nice as the other two options.
Here is another question that is related to your question:
It appears from the response from Coda.io that the ability to share resources between two documents is on the road map, but not yet implemented.
Just FYI if you’re still interested, I recorded a tutorial on how you can sync data from one admin doc to N other docs
