Simple recipe for adding per-user authentication for Google APIs to a Coda pack
The authorization URL and the token URL required to configure OAuth2 authentication were somewhat difficult to find in Google’s docs (found here استخدام OAuth 2.0 لتطبيقات خادم الويب  |  Authorization  |  Google for Developers ), so I thought I would post a template for authenticating Coda packs with Google APIs.
pack.setUserAuthentication({
  type: coda.AuthenticationType.OAuth2,
  authorizationUrl: "https://accounts.google.com/o/oauth2/v2/auth", // see https://developers.google.com/identity/protocols/oauth2/web-server#creatingclient
  tokenUrl: "https://oauth2.googleapis.com/token", // see https://developers.google.com/identity/protocols/oauth2/web-server#exchange-authorization-code
  scopes: [
    // add any scopes your project requires to access user data from their Google Account
    // these will generally correspond to the same scopes you have registered for your app in the Google Cloud Platform
    // note that you must include the entire URL, as the path alone (e.g. "calendar.events" or "auth/calendar.events") is not sufficient
    // e.g.
    "https://www.googleapis.com/auth/calendar.events",
    "https://www.googleapis.com/auth/calendar.calendarlist.readonly"
    // after adding a scope and building a new version, further requests from your pack to the Google API will likely no longer be authorized
    // you will need to connect your pack again to a Google Account from scratch. To do so, remove the pack from your test doc, add it again, and add a new account after clicking to sign in. From there, you will be redirected to a Google consent page where you can authorize the new permissions.
  additionalParams: {
    // these parameters ensure that you get a refresh token in your Google OAuth2 response, allowing the Pack to automatically refresh its access token.
    // @see https://connect.superhuman.com/t/simple-recipe-for-adding-per-user-authentication-for-google-apis-to-a-coda-pack/27547/2
    access_type: "offline",
    prompt: "consent",
// make sure you add the OAuth credentials to the pack, following this guide: https://coda.github.io/packs-sdk/guides/advanced/authentication/#oauth-20
Here is the relevant code without any comments:
  scopes: [
  additionalParams: {
    prompt: "consent",
Thanks for sharing! I think you’ll also want to add the following to your auth config:
  additionalParams: {
    prompt: "consent",
These parameters ensure that you get a refresh token in your Google OAuth2 response, allowing the Pack to automatically refresh it’s access token.
Thanks! Added it to the gist.
Does Google require these prerequisites before using the API with Coda?
Prerequisites
To successfully create your first client application, you must complete the following prerequisites:
  1. Get a Google Account.
  2. Try out Business Profile.
  3. Create a project in the Google API Console.
  4. Request access to the API.
Every Google API is different, but if that’s what the docs says then yes, those will be requirements.
