I’ve created a simple Time Tracker and integrated it into the CRM template - but it also works fine on its own.
I have updated my TimeTracker and added some new cool features
now you can pause your work, as many times as you need
added a overview table for all projects/company’s and the according time spend (incl. time filter)
Edit: v2.1 - logic changes, the temporary table is not needed anymore - all data will be handled within the master data table.
