HI All,
I am having some problems with the slice formula. It doe not return the number of entries that I request. Please let me know whether you can see what is going wrong.
Here is the page (3rd example):
Thanks
Piet
HI All,
Thanks
Piet
Try switching the position of the .Slice() and the .NumberedList() and it should work!
[View of Todo List].sort(ascending: True(), sortBy: [View of Todo List].[Date].Slice().NumberedList()
Thanks! So it did.
I struggled so much to get the sort working in combination with the slice, I ran out of combinations.
