Hello! I’m new here
I’m wondering if there is a way to pull in analytics from Tiktok, instagram, fb etc. And be able to view specific metrics of each post, but then also weekly, monthly etc. Or if there is any template available for this? Or if it would have to consist of manually putting in all the analytics. Thanks!
Hi Nicole,
Welcome to the Coda community!
In Coda packs are tipically used for this kind of use-cases. For example here is one for Tiktok: TikTok Pack, extend Coda with TikTok - Coda
Have not found any for Instagram or Facebook, so I would say you have two options:
- If you’re technical, build your own pack
- Use some platform like Make.com or Zapier to push data from Instagram or fb to Coda: Instagram for Business and Coda Integration | Workflow Automation | Make
Hope this helps,
Pablo
Thank you, I’ll look into this!
