PART 1 - Intro
PART 2 - Making it actually work
PART 3 - Some notes
How I Accidentally Reinvented Union Types for Pizza
I developed this pattern while building a backend for my pizza shop in Coda. I needed to see orders, inventory, staff schedules, and supplier deliveries all in one calendar view, but Coda kept telling me “sorry, no UNION for you.” So I built this solution from scratch.
Of course I used AI to polish the language as English is not my primary.
Here’s the thing—I thought I’d invented something revolutionary. That shower-moment eureka feeling when everything clicks? Yeah, I had that. Then I did some research and realized I’d just rediscovered union types, polymorphic associations, and the adapter pattern. Classic computer science stuff that’s been around for decades.
But here’s what made it worth sharing anyway: I’d found a way to make these proven patterns work beautifully in Coda’s specific environment. The “Unified Interface” design—those simple title_ and dateStart_ columns—turns out to unlock Coda’s formula hinting and dot-notation in ways that make development surprisingly clean. No more brittle SwitchIf() hell.
The real contribution isn’t theoretical innovation—it’s translation. Taking powerful architectural patterns and turning them into a step-by-step recipe that actually works in production. My pizza shop backend became faster to build and way easier to maintain. That felt worth documenting.
The SOOT Pattern: Union Different Tables in Coda
Need one calendar for Events, Tasks, and Training but Coda won’t let you UNION tables? Here’s how to create unified views without messy mega-tables.
Picture this: you’ve got three different tables that describe similar things—events have venues and start times, tasks have due dates and assignees, training sessions have locations and schedules. They’re all calendar-worthy, but they live in separate tables with different column names. Sound familiar?
The SOOT pattern solves this by creating a hub table where each row points to exactly one source record. Think of it as a universal remote for your data—one interface that can control different types of content.
But most importantly for me, it introduces really neat way to do OOP-Style polymorphism. More on this in part 3.
Core Concepts (Really, Just 30 Seconds)
SOOT (Structured One-Of Table) is your hub. Each row points to exactly one source—Event OR Task OR Training, never multiple.
Unified Fields are your adapters. Add columns like title_, dateStart_, location_ to each source table that expose the same data shape, even when the underlying columns have different names.
Source is a formula that picks which pointer is filled. It’s like having one variable that could be a cat, dog, or bird—but it’s always exactly one animal.
Valid? and IB keep your data clean. Think of IB as “Invalid Because”—it lists what’s wrong with a row. Valid? is simply true when IB is empty.
Step 1: Create Your Kinds Registry (Trust Me On This One)
Create a simple table called Kinds with just a few columns:
Name your kinds: Event, Task, Training Add icons: 📅, ✅, 🎓 Maybe add a name template for consistency
This feels like extra work, but it pays off immediately. Instead of hardcoding “Event” in filters everywhere, you reference the Kinds table. When you inevitably need to rename something or add a new type, you change it once instead of hunting through dozens of formulas.
Plus, Coda’s formula autocomplete starts working properly because your type_ fields become proper lookups instead of text strings.
Step 2: Add Your Unified Fields
This is where the magic happens. On each source table, add these simple formula columns:
title_ maps to whatever that table calls its title dateStart_ maps to that table’s start date dateEnd_ maps to the end date (if it has one) location_ maps to wherever that thing happens type_ points to the right row in your Kinds table
For example, on your Events table, title_ might be thisRow.[Event Name], while on Tasks it’s thisRow.[Task Title]. The point is they all expose a field called title_ that your unified view can count on.
Keep these formulas simple and direct. No fancy logic here—if you need computation, do it in a helper column first.
Step 3: Build Your One-Of Table
Create your hub table (call it something purposeful like “Unified Calendar” or “Master Schedule”) with lookup columns for each source table:
Add an Event lookup to Events, a Task lookup to Tasks, a Training lookup to Training. The rule is simple: exactly one of these gets filled per row.
Then add your Source formula—this picks whichever lookup is actually filled:
coda
If(
thisRow.Event.IsNotBlank(), thisRow.Event,
If(
thisRow.Task.IsNotBlank(), thisRow.Task,
If(
thisRow.Training.IsNotBlank(), thisRow.Training,
List().First()
Now for the payoff—your unified reads become clean one-liners:
Title becomes If(thisRow.Source.IsBlank(), List().First(), thisRow.Source.title_)
Notice how this works? Once you have Source pointing to the right record, thisRow.Source.title_ gives you the title regardless of whether it came from Events, Tasks, or Training. Coda’s dot-notation just works.
Set up a display column that shows something readable, add some basic validation, and you’re done.
Daily Usage (The Part That Actually Matters)
Here’s how it works in practice: keep adding Events, Tasks, and Training to their original tables like always. Create rows in your unified table that point to them. Build your calendar view on the unified table, filtering to Valid? = true.
The beautiful part? You edit data in the source tables where it belongs, but you operate from the unified view. Click on a unified row and it takes you right to the source. No data duplication, no sync issues.
Coming up in Part 2: How do I automate this so I don’t manually create unified rows? What’s this VIBE pattern for validation everywhere? And how can I make buttons work uniformly across different types?
Part 3 preview: What computer science concepts am I accidentally using? How does this scale? What are the gotchas I should know about?
Are you struggling with these Coda challenges?
Need to show Events, Tasks, and Projects in one calendar but they’re in separate tables?
Want to combine different table types in a single view without messy mega-tables?
Frustrated that Coda doesn’t have UNION functionality like SQL?
Looking for a way to merge multiple tables into unified boards, timelines, or dashboards?
Need one view for different data types that updates instantly and stays fast?
The SOOT Pattern solves this. It’s a systematic approach to create unified views across different tables without losing performance, native Coda functionality, or data integrity. Used successfully in production docs ranging from pizza shop operations to complex project management systems.
Search terms: Coda union tables, combine multiple tables, unified calendar view, merge different table types, single board for events tasks projects, Coda table consolidation
