Hello! I am on the brink of solving this problem after trying to work with ForEach for so long and I think at this point I need some help.
I have this client data in the top table that I would like to split into the rows in the bottom table, and the dataset needs to change based on the selector. Any advice here? I feel like I’m SOCLOSE to solving this on my own but I just can’t figure out this last bit to split it into the rows.
If you would like to play around with it, here’s a test doc I put together.
