Stuck on copying one column data to another
Hi! I thought this part was easy but apparently, it is not. How can I copy one column data to another column? Below is the formula I have with a button but it it copies just one value in the entire column. Here is my sheet, you might need to request access to the sheet.
[Projects].Foreach(
    ModifyRows(
      [Projects],
      CurrentValue.[Previous priority],
      CurrentValue.Priority
This should work, assuming you want to populate the [Previous Priority] column with the [Priority] columns value.
You can write it as
[Projects].Foreach(
    CurrentValue.ModifyRows(
The first item to pass to the ModifyRows using this approach is the name of the column, the second item is the value to set the column.
wow thanks @Daragh_O_Shea1 ! It works! Can I ask why you did CurrentValue.ModifyRows? The foreach already iterates through each item , why did you need to prepend CurrentValue to it as well?
In a ForEach loop on a table like this, CurrentValue is the current table row in the loop
Prepending the formula is just a different way to write it. It could also be written like this:
Projects].Foreach(
   ModifyRows(
     CurrentValue,
Each row is being updated individually in the loop
Thank you for the explanation! I reread the definition of ModifyRows and I did see that the first input was a row, not a table. :slight_smile: Cheers!
