Hi Community,
I have a problem which seemed to be simpel but I don’t get any further after trying several formulas.
I have one table with one column with number of holidays and another column with their stage (3 possible).
In another table I have 3 columns for these stages and just want to get a the sum of the first table but only for the specific stage.
I know there is a solution in Excel but how is the formula in Coda for that?
Kind regards
Mario from Germany
HI Mario,
Here is an example using sumIf():
You could also click on the link to sum() and make use of it in conjunction with a filter().
Hope this helps.
Piet
Thanks for your reply,
unfortunately I already tried SumIf and Filter but something seems to be missing.
For example when I try the following formulas, it searches in the “Stage” column if there is a “planed” somewhere, and if so, it sums up the whole column “Holidays” and gives me 26 as result. But I expect as result 13 because only these Holidays are in Stage “planed” …
a) t_urlaubs_planung.Holidays.SumIf(t_urlaubs_planung.Stage.Contains(planed))
b) t_urlaubs_planung.Holidays.SumIf(t_urlaubs_planung.Stage.Filter(planed))
Any idea what the right formula is to get this working?
Hello @Mario_Kiessling
This is very easy to do correctly - please make and share a dummy doc in which we can show you the solution.
There is more than one way to do this, but the formulas could look something like:
TableName.filter(currentvalue.Stage=@requested).Holidays.sum()
Or even simpler: make a view of your table, group on Stage and show the sum() of Holidays.
I don’t like SumIf, but I guess that could work too.
Greetings, Joost
Hello Joost!
That was the right formula and it works perfectly!
Thank you!
Greets from Germany
