Sync columns between two tables
Hi,
I’ve synced two different google sheets to coda and now i’d like to sync one column from a table to the other table. As coda does not allow to create charts using values from different tables this is the only work around i found.
But i’ve tried relation columns, lookups … but i cant make it work.
Please let know how this can be done.
I’ve attached a sample doc with two tables “Parent” and “Kids”. All i want is to get the datas filled in the second table - Parent names corresponding to Kids names.
Hi there, your Relation columns look set up correctly. If you’d like this data brought in automatically, you can do this via formula. I added in a column in your Parents table called Coda Support Test with a formula that will do this for you. Take a look and let us know if that’s more what you were hoping for :+1:
