I would like to know if there is a way to sync tasks with due date with an external calendar like Outlook or Google Calendar, without having to pay for the Pack, if possible. Or if there is any way to see the tasks in a widget on mobile devices, to have a quick view of what I have to do. I appreciate any suggestions or advice you can give me. Thanks for your attention.
You can try using third party apps to get this working but they are usually limited in their free plan as well. Or you can create a own Script with the API that works for you.
But frankly I don’t think there are many ways around paying for something.
Sincerely
Jannis
Finally, I was able to synchronize any task or event from Coda with the Outlook calendar and now I can view everything I need from the iOS and MacOS widgets. I achieved this by using webhooks and an automation platform, for free (up to 1000 operations per month). Thank you for your response.
